Iphone sync cable not same as ipad cable
Discussion in 'iPad General Discussions' started by swelson, Apr 30, 2010.
  1. swelson
    swelson
    Mar 4, 2010
    48
    Apparently not. Try using the cable that actually came with the iPad. There is apparently something different about it. Now, backup and sync on my iPad fly
    NOW YOU HAVE TO MARK YOUR CABLES
    NICE JOB APPLE:(:(
  2. Tucker
    Tucker
    Apr 20, 2010
    41
    Hmm...my old cable worked fine
  3. Bremen
    Bremen
    iPad Addict
    Apr 5, 2010
    1,350
    5
    I have used my iPhone cable to sync from day one. I have not even taken the one that came with the iPad out of the box...... Have no idea what you are talking about.....
  4. Rasputina
    Rasputina
    Mar 24, 2010
    307
    it's the same damn cable. I've used multiple cables from my various devices they all charge it. The only thing different is the ac adapter part.
  5. swelson
    swelson
    Mar 4, 2010
    48
    WELL MAYBE MINE HAS AN INTERMITTENT BUG OR SOMETHING
    THE IPAD CABLE DOES NOT LET THE IPAD DROP OUT DURING SYNC AND THE OTHER DOES
    Hmmmmm
  6. Max
    Max
    Feb 3, 2010
    344
    64
    Baaaack aaawwwaayy from the caps key........you can do it! :)
  7. nursedina
    nursedina
    Apr 7, 2010
    68
    Swel - I had the same problem. My iphone cable synced very very slowly and got hung up a lot, when I used the other cable, it went fast-no problem. I even tried it again with the old cable and the same thing happened.
  8. Ltapilot
    Ltapilot
    Apr 11, 2010
    16
    Your old cables may be damaged.
    My iPod cable is working fine.
  9. GrendelPrime
    GrendelPrime
    Apr 21, 2010
    41
    I must have half a dozen USB i-cables, and a Firewire version somewhere.
    So far no noticeable difference between generations in compatability or speed (except the Firewire).
    I agree with the assessment that you old cable is most likely damaged.
  10. DavidNM
    DavidNM
    Mar 22, 2010
    548
    My iPod touch cables are working fine without any problems
difference between ipad and iphone cable
difference between iphone and ipad usb cable
do ipads and iphones use the same cables
does same power cable work for iphone 4s and ipad2
i pad air cable and iphone 5 cable difference
ipad and iphone cable difference
ipad cable different from iphone
is iphone 4 sync cable compatible with ipad 3
is the cord ofthe ipad 2 and the iphone 4the same
is the ipad cord the same as the iphone cord
