ipad2 screen problem - shows for split second?
Discussion in 'iPad General Discussions' started by stuee, Jul 4, 2014.
  1. stuee
    stuee
    May 1, 2013
    Hi All
    I just turned on my ipad today to find when i turn on there is no logo, then after a min when i press the power button or home it shows the lock screen and clock for a slpit second then black again.
    Ive tried the power / home reset and still the same.
    Anyone know of this problem or how to fix. The lcd isnt smashed neither is the screen.
    thanks in advance.
  2. abababababab
    abababababab
    iPad Super Guru
    Apr 21, 2013
    4,139
    694
    I think you should have a diagnostic run of your iPad at the Genius Bar of your nearest Apple store.
  3. J. A.
    J. A.
    Staff Member
    Nov 11, 2012
    18,985
    11,594
    Make sure the iPad is charged. If you're not certain about it, plug it in.
    Try to restore it using iTunes. If this doesn't help, you'll need to take it to the next Apple store, as abababababab suggested.
i pad shows previous site for a second
ipad shows previous site for a second
