ipad2 phot deleting problems
Discussion in 'iPad Help' started by suja, May 12, 2011.
  1. suja
    suja
    May 12, 2011
    Hi, I wanted to delete one photo from Photo library, but not able to . Neirther the delete button is active nor the trash
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    I've moved this post to the Help section, where I think you'll get better attention. I hope this is OK.
    However, if a photo on your iPad was added through a sync operation with your PC it cannot be deleted from the iPad. You have to remove it from your PC and then resynch. Only photos that were added to your iPad not through a synch - perhaps received as an email attachment - can be deleted on the iPad itself.
    If you need to be able to do this, there are several third-party apps out there that have this capability.
  3. OneMarcil
    OneMarcil
    Mar 30, 2011
    121
    6
    What are the names of those applications?
    Sent from my IPAD 1st generation. WIFI only. 32 GB
  4. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
how to delete photos from ipad photo library
how to delete photos from my photo library on ipad2
ipad 2 photo delete problems
