iPad Wifi Internet connection using Camera connection kit + 3G USB modem?
Discussion in 'iPad Hacking' started by nparab, Aug 9, 2010.
  1. nparab
    nparab
    Aug 9, 2010
    I have a jailbroken iPad wifi (non 3G) and I've recently bought the camera connection kit which has a USB port (which supposedly detects/connects to even non-camera devices like USB keyboards, USB flash drives, etc).
    I was wondering if it would be possible to attach a 3G USB modem/data card and make the Internet work without wifi? The 3G data card otherwise requires a bare-minimum wvdial from a normal Linux terminal.
    So,
    1. Can I get/install the wvdial .deb package on my jail broken iPad?
    2. If I can get the package, will this work (wvdial detecting and using the USB modem and connecting through it?), or is it too far out?
    Thanks for your help and suggestions.
  2. MikesTooLz
    MikesTooLz
    iPad Ninja
    May 7, 2010
    2,361
    20
    not gonna happen. you need drivers for the device
  3. nparab
    nparab
    Aug 9, 2010
    Thanks for your reply Mike.
    On a normal Linux terminal, no drivers are required. You just set wvdial config as 'analog modem' and point it to /dev/ttyUSB0 or something like that. I got this info from a link, which I can't post right now because I haven't posted 3 times on the forum yet.
    That's what got me thinking that if I can get the wvdial package, it would work. I know this is a bit far out, but maybe possible?
  4. MikesTooLz
    MikesTooLz
    iPad Ninja
    May 7, 2010
    2,361
    20
    yeah because it already has basic universal analog modem drivers.
camera connection kit usb modem
can camera kit for ipad works for mobile inernet
connect usb modem to ipod 2
ipad 3g usb modem
ipad connection kit with data modem
usb data card with ipad
use 3g usb modem on ipad
wifi cam for ipad 1
wifi ipad wvdial
will camera connection kit work with international modem
