Ipad VPN connection problem
Discussion in 'iPad General Discussions' started by ec333, Jul 14, 2011.
  1. ec333
    ec333
    Jul 14, 2011
    Hi
    I am having trouble connecting my iPad to my company's VPN. I have setup all settings correctly using IPSec (the reason I know this is because when a co worker uses his credentials to login using my iPad it works perfectly when I use my credentials the credentials box keeps on popping up and so doesn't accept these.)
    When using my laptop to connect using cisco VPN client I can connect fine.
    Does it possibly have to do with the my user profile settings/access on the company's active directory?
    Please help....
  2. thewitt
    thewitt
    iPad Ninja
    Jun 5, 2011
    1,633
    73
    The log file on your VPN will tell you what the error is. See your administrator.
    -t
cisco vpn ipad problems and solutions
connection problems with express vpn and china mobile on ipad
ia m having trouble connecting to vpn in canada on an ipad
im having problems with vpn on ipad
ipad vpn connection problems
ipad vpn problem
troubleshooting vpn connections on ipad
vpn connection problems on ipad
vpn ipad problems
vpn problems on ipad 2
