IPAD - Sticky (not smooth) screen problem !!!!!
utisz
Hello. I have a very simple problem with my ipad that drives me INSANE. My screen feels sticky. it's not sticky that much but I can not softly slide my finger on the screen, and it really prevents playing games, writing with hand, painting and simple (but important) stuff like that.
I did not clean my ipa with anything other thana drop of water and mirofiber so far. I did not use any chemicals on it. Did not stick or remove anything of it. I'm using it exactly as I should, but after 3 weeks of using it, I felt this feeling in the starting of this week. Right now it's driving me insane, literally !!
I searched / googled about this simple problem, but most of the people having the same problem somehow used chemicals on their screens.
I bought my ipad from another country so it seems like its impossible for me to take it to the warranty check within a sooner time range.
Any ideas ?!
ChIpad
NH
I searched and found someone with same problem, they used a dab and only a small dab of water, and then repeated in a few hours and it was fine, make sure you wipe it back off.
Anfield800
UK
For what it's worth, I've never put anything on my iPad. I clean the screen with a glasses cloth, and if I feel 'stickiness' (is that a word?) I wash my hands. Sorts it for me.
U
utisz
tried both of them again and again.... still the same...
I cant even play "spirit"..... SO irritating. its like a regular clean class that you try to rub with your finger --- it sticks.
ChIpad
NH
I have never had that but then again from day 1 I have had a screen protector on mine, that might be why
tap50
Virginia
I use a cleaning spray that I got for my glasses from my eye doctor and a microcloth to clean my iPad screen. The screen always has a smoother glide to it after I clean it this way. I have a Zagg screen protector on it too.
Todd
PacketRat
SC
you can also use a window tint film cleaner.. they have some additives that makes it smooth.
U
utisz
as I know window cleaners are harmfull to the ipad X___x
U
utisz
I didnt clean it with a window cleaner for sure.
it's still the same as when I opened the topic. Maybe "sticky" is not the word, maybe I can tell this:
Its's hard to move the finger on the surface, it feels like there is a lot of friction.
Kenworth
Apple recommends IKLEAR for all these "I" screen types.....which they sell.
totoraven
IpadLand
hmmm... is it the screens problem or your hand? if its your screen use a screen protector its just cheap if its your hand apply powder to
your hand (it can be any powder) this actually worked for me.
hope this helps! :thumbs:
scifan57
Regina,Canada
It may not be a good idea to use powder on your hands while using the iPad. There's too much chance of some of it coming off the hands and finding it's way inside.
totoraven
IpadLand
if he doesnt want that option then he has no other option than buying a screen protector
