iPad seems totally dead - please HELP !!!
Discussion in 'iPad Help' started by DM51, Dec 3, 2010.
  1. DM51
    DM51
    Aug 19, 2010
    669
    ** FIXED! ** iPad seems totally dead - please HELP !!!
    Aaaaargh!
    My iPad has died!
    None of the buttons make any difference, no sound, no display, plugging into charger makes no difference, connecting to computer doesn't register on iTunes, NOTHING WORKS!!!
    If this is a clue to what is wrong, I had left it running a pdf file in Goodreader - I just didn't switch it off after reading it, as I was busy with something else. I assumed it would power off if it needed to.
    Helppppp!!
    #1 DM51, Dec 3, 2010
  2. rwilts
    rwilts
    Apr 5, 2010
    62
    Don't panic
    I had that a few months back, very similar circumstances not good reader but running something else. I think I did a hard reset, hold home and power together and it will eventually reboot. No issues since:)
  3. DM51
    DM51
    Aug 19, 2010
    669
    Thnaks!!
    I'll try that - VMT! :)
  4. DM51
    DM51
    Aug 19, 2010
    669
    It worked!
    It worked! Back on as if nothing had happened. Can't thank you enough for your super-speedy response - I owe you a large beer :) !
    Now I better go and change my panic-stricken sigline, LOL
  5. rwilts
    rwilts
    Apr 5, 2010
    62
    Lager,bitter,White wine but definitely not Red:mad:
    Glad sorted.
  6. Wa4vif
    Wa4vif
    Nov 25, 2010
    6
    mine died, too!
    This morning, while running Pulse newsreader, I laid it down to answer the phone. Two minutes later when I picked it up, the screen was blank and it would not respond to any button presses. drawing on the old iPaq habits, I held down the Home and Sleep keys and it came back up the out-of-the-box iTunes connection screen. had to restore from ground zero. I lost some apps that I had added since last sync (which was at the 4.2.1 update). I hope this is not a recurring problem. I have since seen several posts with similar issues. Again I am reminded that I should have waited on the Android tablets.
  7. NumbLock
    NumbLock
    iPad Ninja
    May 2, 2010
    2,008
    32
    I also just had this happen yesterday (Friday). Frustrating and scary, but it happened once before too, so I knew what to do.
    To be honest, I was also using GoodReader heavily at the time, and doing something funny with rotation and safari when it went dead.
  8. DM51
    DM51
    Aug 19, 2010
    669
    Thanks to all! It was quite worrying, and of course I couldn't get at the iPad user guide or help to find out how to deal with it.
    Numblock, I just filed a report on post #1 to ask for the thread title to be changed. I tried editing post #1 in advanced mode, but the title has stayed the same.
  9. Digikid
    Digikid
    Aug 15, 2010
    567
    The link here seems to be Goodreader. Would recommend that you remove the app and notify the creators of Goodreader and tell them what happened.
completely dead ipad
ipad 1 completely dead
ipad completely dead
ipad has no power
ipad is totally dead
ipad seems dead
ipad totally dead
my ipad is completely dead
my ipad seems be dead
totally dead ipad
