IPad Numbers Problem
Discussion in 'iPad Help' started by JWhitTX, Oct 24, 2011.
  1. JWhitTX
    JWhitTX
    Oct 24, 2011
    I've created a spreadsheet in Numbers and want to use a form to input data. But, when I pull up a form for the spreadsheet it will not give me a text keyboard so that I can enter text. I get only a numeric keyboard. I want to enter data like names in individual cells. How do I get the form to accept text data?
  2. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,772
    6,738
    Make sure you've formatted the cells as text in the table you are using to make the form.
    Since you can switch modes/keyboards when entering data to the table, this is easily overlooked; but it determines what keyboard will pop up when you select teh field in a form.
    You can change an entire row or column of cells at once. Just select the table, then tap the gray bar opposite of the column or row to select it all. Go to the controls (the i icon), select the format tab, and choose Text.
    Headers are formatted as text by default. All other cells are formatted numeric by default (though that does not show in the control panel).
  3. JWhitTX
    JWhitTX
    Oct 24, 2011
    Yes, that was exactly the problem. It's working great now.
    Thanks!
  4. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,772
    6,738
    Glad to hear it worked.
apple numbers problem entering text
ipad numbers find problem
ipad numbers input forms
ipad numbers not working
ipad numbers problem creating forms
ipad numbers spreadsheet will not accept text in cell
numbers for ipad not working
numbers not working ipad
numbers not working on ipad
numbers not working on my ipad
