Ipad mini itunes connection problems
Discussion in 'iPad Mini Forum' started by scoobiedoo, Apr 28, 2013.
  1. scoobiedoo
    scoobiedoo
    Apr 28, 2013
    Hi all,
    After eventually getting iTunes to download onto windows 7, I now find that it does not recognise my mini. It states that the mobile device driver did not load and to reinstall iTunes. I've tried this, but still have the same problem. I did notice when downloading that the error message came-up stating that I didn't have permission to download the mobile device driver.
    Any suggestions greatfully received - can I download the driver on it's own? If yes, how and where do I save it to?
    Thanks in advance.
    Scoobie.
  2. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,675
    1,476
    Are you using an administrator account on Windows 7?
  3. scoobiedoo
    scoobiedoo
    Apr 28, 2013
    Hi,
    I downloaded the iTunes installer to my desktop and ran it as an administrator.
    Thanks,
  4. alicepattinson
    alicepattinson
    Jan 23, 2013
    182
    11
    Does it sync now?
  5. AQ_OC
    AQ_OC
    iPad Wizard
    Apr 28, 2011
    6,415
    435
    Have you tried a different usb port? Sometimes, some windows PCs have flaky ports. I suggest you try them all one by one.
  6. scoobiedoo
    scoobiedoo
    Apr 28, 2013
    Hi,
    Thanks for the replies.
    I've tried different ports, but to no-avail.
    Even downloading as an admin, it will load everything bar the mobile device driver - when I check in the iTunes folder it's ot there.
    Thanks.
connect to itunes problem with ipad mini
ipad mini itunes connection problems
ipad mini itunes problems
itunes connection problem for mini ipad
itunes connection problems ipad mini
itunes connection problems mini ipad
itunes connection problems with ipad mini
problems loading itunes on ipad mini
