ipad goes into recovery mode again and again .
Discussion in 'iPad Help' started by doga, Oct 8, 2011.
  1. doga
    doga
    Oct 8, 2011
    hi,
    my ipad 1 was working correctly then suddenly it stopped working . when i restarted it worked for few minutes then again stopped . the screen goes blank and nothing happens .
    i tried to restore it and it works but after few minutes of use it again stops working and goes into recovery mode when i connect it to itunes .
    please help me out .
  2. SweetPoison
    SweetPoison
    iPad Legend
    Jun 20, 2010
    14,913
    133
    Are you Jailbroken?
    Try a hard reset. Hold the power button and the home button down at the same time until you see the Apple logo. Takes about 10 seconds. Let it reboot. See how that works!
  3. doga
    doga
    Oct 8, 2011
    no i didn't jailbreaked andi also i am not using any kind of custom firmware files .
    hard reset doesn't works for me . it works only for going into DFU RECOVERY MODE which restores the ipad but again after few minuted of working ipad it again stops and then when i connect to itunes it says to restore it .
  4. doga
    doga
    Oct 8, 2011
    i have tried everything . also with custom firmware
    please help me
ipad 2 keeps going into recovery mode
ipad keeps going into recovery mode
ipad keeps going to recovery mode
ipad2 goes into reset
my ipad 2 went to recovery mode
stop ipad recovery mode
what to do when i pad goes into recovery mode
why did ipad go into recovery mode
why did my ipad go into recovery mode
why does my ipad keep going into recovery mode
