ipad does charge using usb
jim_joh
calif
When I connected my ipad to my computer ( using usb) the battery showed 80%. l unplugged it 3 hours later and the battery showed 100% During that period of time it was tuned off so it does charge using usb. jim+joh
Ghuda
Seattle WA
I always get the warning that I can get faster connections if I use a USB 2 port, but I don't have any.
So far as data transfer speed I imagine the newer 2.0 is better, but what about power level? Is this also increased with a newer 2.0 port?
Techdad2
California
Not all usb ports are equal in redgards to supplying power to peripherals, sometimes utilizing a port in the back of the pc rather than the front will solve the problem. A powered usb adapter can work wonders also.
Ghuda
Seattle WA
Never thought of the powered hub, good idea. I have an older Belkin 5 port hub for my laptop. This could be a nice alternate when I am at the office.
I will give is a shot tomorrow and see how well it works.
gjperera
Miami, FL
Website
www.gilsmethod.com
My Belkin powered hub gives me trouble with the iPhone and the iPad, I have to connect these two directly to my PC and they charge with no problem. I've also found this issue running portable HD's without a power supply, the USB hubs don't run them well.
J
jim_joh
calif
Using a pc. In fact it is a usb slot in my Dell monitor. jim_joh
Dorje
I've never had good results from Belkin products. It all seems to be overpriced junk of questionable quality.
Techdad2
California
I have my ipad connected to my imac so no usb problems, however when using a pc sometimes there's always one port on a tower that acts up, system usb cards can go bad at times requiring them to be replaced.
Sonny Burnett
Boston, MA
Here is the official Apple tech article on this:
iPad: Charging the battery
  • Last Modified: April 04, 2010
  • Article: HT4060
Summary
iPad has an internal, rechargeable battery. To charge the battery, try the following:
  • Connect iPad to a power outlet using the included cable and the 10W USB power adapter.
  • Connect to a high-power USB 2.0 port using the included cable.
Note: Some USB 2.0 ports and accessories do not provide enough power to charge iPad. When this occurs the message "Not Charging" appears in the status bar next to the battery icon.
Products Affected
iPad
An icon in the upper-right corner of the screen shows battery charging status and approximately how much charge is left in the battery. If you charge the battery while syncing or using iPad, it can take longer to charge.
Rechargeable batteries have a limited number of charge cycles and may eventually need to be replaced. Battery life and the number of charge cycles vary by use and settings. For information on how long the battery is expected to last between charges, see the iPad Technical Specifications.
Charging Tips
The fastest way to charge your iPad is with the included 10W USB Power Adapter. iPad will also charge, although more slowly, when attached to a computer with a high-power USB port (many recent Mac computers) or with an iPhone Power Adapter. When attached to a computer via a standard USB port (most PCs or older Mac computers) iPad will charge, but only when it's in sleep mode. Make sure your computer is on while charging iPad via USB. If iPad is connected to a computer that’s turned off or is in sleep or standby mode, the iPad battery will continue to drain.
Additional Information
If iPad is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, try connecting to the 10W power adapter.
When charging iPad using a computer's USB 2.0 port, make sure the computer is plugged in to power and not in standby, sleep, or hibernation mode. iPad does not charge when connected to an older accessory that only supports FireWire charging. When connected to these accessories, iPad will display the following alert:
"Charging is not supported with this accessory."
Source: iPad Charging the battery
