Ipad display problem
Discussion in 'iPad Help' started by ZeeDD, May 29, 2010.
  1. DefBref
    DefBref
    Apr 14, 2011
    978
    53
    You can restore your new iPad from a backup of your old one in iTunes. Make sure you have an up to date backup before you exchange your old iPad by connecting it to iTunes and allowing it to sync.
  2. baconator
    baconator
    Jul 9, 2011
    6
    Thanks so much for the help. :)
    Should I let them do this for me at the Apple store? or will this be easy for me to do myself?
    And, how can I make sure ALL of my passwords are totally erased off of this defective ipad2? Will clear history & cache do this? (or do I need to change all of my passwords?)
    #12 baconator, Jul 23, 2011
  3. DefBref
    DefBref
    Apr 14, 2011
    978
    53
    No they won't be able to do it in store, you need to sync with your own itunes library.
    You can erase all contents and settings on the ipad (once you've done the backup).
  4. baconator
    baconator
    Jul 9, 2011
    6
    Done! :D
    I actually figured it out on my own. LOL. (I am actually starting to like Apple more than windows:) )
    I called the Apple store and they said they would exchange it - no problem at all. Now I just need to find an Apple store in the area that HAS a white 32G iPad2....that will prove to be more difficult.
    I will report back when exchanged.
  5. baconator
    baconator
    Jul 9, 2011
    6
    While I am waiting on the Apple store to replace(get them back in stock) my ipad 2 because of the “white spot” on my screen I thought I would post a couple of interesting articles I came across. (just a couple of MANY on Google when I typed in “white spot on my ipad screen”)
    Bright spot on screen
    https://discussions.apple.com/message/13226058#13226058
    If Your iPad 2 Has Display Problems, DO NOT Return It. Here’s Why
    http://www.cultofmac.com/if-your-ipad-2-has-display-problems-do-not-return-it-heres-why/87197
apple ipad display problem
ipad air screen problem
ipad blank screen
ipad blank screen problem
ipad display problems
ipad no display problem
ipad screen display problems
ipad screen problem
ipad screen problems
