iPad connection problem
Discussion in 'iPad Help' started by kitnchuck, Mar 17, 2011.
  1. kitnchuck
    kitnchuck
    Mar 17, 2011
    Last weekend, my iPad stopped connecting to my home wi-fi, although it has been problem free since Labor Day weekend. The wi-fi still works - I am using it with my laptop now. My iPad works just fine on the wi-fi at my work.
    It says that it is hooked to my network, but when I try to connect, the error message reads:
    Safari cannot open the page because it is not connected to the Internet.
    If I turn on the cellular data tab (which costs me money), it seems to be unable to read the att data until I actually close the wifi network. Then it works just fine.
    Do you have some suggestions for me to try? Thanks in advance.
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    Scotlan
  3. kitnchuck
    kitnchuck
    Mar 17, 2011
    Didn't work... :(
    Thanks for the reply, Tim. I knew about closing the apps by double clicking and then pushing the jiggler thing. However, that didn't work.
    I powered down (don't know why I had forgotten that!). However, still no wifi connection.
    I could contact my internet provider, but since the laptop works, I don't know what they could do.
    Should I take my iPad to the Apple store?
    #3 kitnchuck, Mar 17, 2011
  4. kitnchuck
    kitnchuck
    Mar 17, 2011
    i just tried my email also, and get the error message:
    The mail server "imap.gmail.com" is not responding. Verify that you have entered the correct account info in Mail Settings.
    Again - this worked fine until a few days ago....
  5. twerppoet
    iPad Legend II
    Jan 8, 2011
    21,113
    7,309
    Go into Settings >> Wi-Fi and select your wireless network (blue arrow on right). Tell it to Forget this Network. Back out and join the network again. This is more thorough than Renewing the Lease.
    Never hurts to reset the router. Sometimes they start blocking specific MAC addresses for one reason or another. A reset usually clears this up.
    If that doesn't work you could try forgetting the network, resetting the router, then join the network again.
    There is also the soft reset. It probably won't help with this kind of problem, but you never know. Hold down the power and home button until the Apple logo appears; about 15 to 20 seconds. Release and wait for it to finish rebooting.
  6. Onaga1555
    Onaga1555
    Mar 21, 2011
    kitnchuck: Any luck with resolving your problem? I am experiencing the same difficulty. (I would send a PM, but I am new to this forum and do not have enough posts to send a PM.)
  7. mossfur
    mossfur
    Mar 8, 2011
    23
    mossfur
    I had the same problem with my ipad,other units like laptops worked off my router and my ipad worked fine at local wifi hot spots,all Apple techs concluded that it was my router,got a new NetGear and my ipad worked great.
  8. Onaga1555
    Onaga1555
    Mar 21, 2011
    I finally got tired of trying to "fix" the problem and purchased a new wi-fi router. All is now fine. (Admittedly, the old router was VINTAGE.)
  9. Phine00Del
    Phine00Del
    Mar 12, 2011
    93
    I'm also having this issue and it's driving me nuts. I've had my new iPad since the day they came out and have never had any issue connecting to wifi. Yesterday at work I had some trouble getting it to connect but it finally connected after about 5 minutes. Today I'm back home and it will not connect to my home wifi. It's doing the same thing other people have described- it locates the network and in the network setting looks likes it's connected but no little wifi icon in the top left corner. I've tried forgetting the network, renewing the lease, multiple restarts, and restarting the router and it still won't connect. I know the wifi is working because my husband's surfing the web the whole time on his laptop. I can't just upgrade the router because it's a U-Verse integrated wifi router. I would have an issue upgrading the router anyway because it's worked in the past and works with my husband's laptop, this is clearly an iPad issue.
    Of course later today I'm supposed to show my iPad to a friend who's interested in buying one. Not exactly good marketing if I can't even get on the internet with it. I'm so frustrated I'm almost ready to throw the iPad out of the window. It's wifi only and since I mostly use it to get on the internet, it's a useless paperweight at the moment!
    Has anybody with this problem found a solution?
    Thanks.
    :mad:
  10. DontUnderstandMyIpad
    iPad Guru
    Jan 22, 2011
    3,192
    13
    You could also restart the router, either via software (most routers can be accessed via 192.168.2.1) or simply unplug the router for 15sec.
connection error ipad
connection error on facebook ipad app
connection error on ipad
facebook connection error ipad
facebook connection error on ipad
ipad connection error
ipad connection error message
ipad connection errors
ipad facebook connection error
ipad won't connect to att uverse
