iPad camera connection kit + ifile- is lower voltage ok with sd cards.
Discussion in 'iPad Hacking' started by legendofcurlysgold, May 15, 2011.
  1. legendofcurlysgold
    legendofcurlysgold
    May 15, 2011
    9
    Hi,
    Great forum, I travel a lot and use goodreader and avplayer app for video. I have read that in 4.2.1 the voltage was lowered which made USB hit and miss certain ones would work others not.
    My question is do sd cards which presumably take less voltage always work? I'd like advice before I buy a cck and 32gb sd card to put my movies and stuff on.
    Also is it better to get a full sized sd or a micro sd with adapter or does it not matter? I know I can get a aftermarket 5-1 cck from eBay for 11 pounds.
    Thanks for any advice in advance.
  2. wytey
    wytey
    Mar 29, 2011
    768
    7
    all the ones I tried works fine, different story for the USB one though, only my corsair flash voyager works
    icouldsave.co.uk - help save money and the planet!
  3. legendofcurlysgold
    legendofcurlysgold
    May 15, 2011
    9
    Thanks Wytey, looks like I'll get the CCK and a SD card.
  4. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,651
    35
    Oh, that's a good point. I didn't think about SD cards. But I am sure they work the same.
  5. Hackint0sh814
    Hackint0sh814
    May 5, 2011
    36
    I've used my CCK with at least a dozen different SD cards, even a microSD with SD adapter and never had one not work. I think you'll de fine no matter what type or size SD you use.
  6. Frenchroll
    Frenchroll
    Apr 29, 2011
    37
    Same here, every Sd/micro sd card no matter the capacity or class has worked fine for me, remember even if you have say an avi or flv file that you need to play in avplayer hd, you can use ifile to setup a link so you don't have to store the file on the iPad itself to view it!!
    #6 Frenchroll, May 15, 2011
  7. Hackint0sh814
    Hackint0sh814
    May 5, 2011
    36
    +1 on the AVplayerHD. I've got a 64GB iPad and I still use my 16GB microSD card for storing movies and watching them.
  8. legendofcurlysgold
    legendofcurlysgold
    May 15, 2011
    9
    double post
    #8 legendofcurlysgold, May 15, 2011
  9. legendofcurlysgold
    legendofcurlysgold
    May 15, 2011
    9
    Great replies. I'm getting a sd card and using avplayerhd I wasn't too bothered about USB functionality. I just need more storage for movies when I'm stuck in hotels with foreign tv its either get this working or lug my beasty dell 1525 about :)
    I have bought the kit and a sd online need to wait for delivery, in the meantime could you please explain this process for me please?
    Do I have to put the files in a specific folder on the card?
    How do I setup the link for avplayerhd using ifile?
    Thanks in advance.
  10. Frenchroll
    Frenchroll
    Apr 29, 2011
    37
    I assume you are jailbroken, install ifile from cydia if you haven't already, load up your files anywhere on Sd card, no specific folder needed, pop the Sd accessory into iPad, open ifile and if you select sidebar button you will see your flash drive under short cuts, select it then hit edit in top right corner, then select the file you want to create a link for, then in the bottom right corner tap the clip board, then tap copy/link, then select done, then select applications under short cuts select applications, then avplayer hd , then documents, then edit, then clip board, then create link, then done, so the next time you go into avplayer hd app you will see links from Sd card :)...ps if when you select applications under settings and you see a bunch of letters and numbers instead of app names, simply tap settings in bottom left corner then turn on application names.....this process can be used with many apps on iPad like good reader, beatmaker 2 etc....
    #10 Frenchroll, May 15, 2011
32gb micro sd to ipad connection camera kit
av player hd to camera roll
avplayerhd play from cck
how to playvideo from ifile using av player hd
how to use ifile on ipad to watch movies
how to watch rmvb files on ipad via ifile
ifile cydia camera kit ipad mini
ifile read movie sd card
sd card ifile ipad
voltage de ipad 1
