iPad Battery Drain
Discussion in 'iPad General Discussions' started by SallySparrow, Jan 1, 2011.
  1. SallySparrow
    SallySparrow
    Jun 26, 2010
    19
    How much battery life does your iPad drain when you leave it overnight? When I went to bed, I unplugged it from the charger and it was at 100%, and it lost about 10% of charge in around 12 hours in standby mode.
    I wasn't really tracking the battery life before, but I'd like to know if anyone else has any idea if this is normal.
  2. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,651
    35
    If you have it set to check for emails often that will drain your battery but it will drain maybe 1/2 to one percent over a 12 hour period. So something isn't right. That isn't normal.
  3. SallySparrow
    SallySparrow
    Jun 26, 2010
    19
    That's what I thought. I remember having to charge it just once every week to 10 days, and now it's always on the verge of dying.
    Thanks.
  4. SBHOKC
    SBHOKC
    Dec 25, 2010
    422
    You may want to try a reset by holding the home and sleep buttons down until the Apple logo comes up (about ten seconds) and then releasing them. Clears the RAM among other things.
  5. SallySparrow
    SallySparrow
    Jun 26, 2010
    19
    I tried resetting, and restored it to factory settings a couple times over the last few weeks, but nothing seemed to change.
    Finally went down to the genius bar right after I posted here, and they just swapped mine out for a new piece. Can't say I'm disappointed!
  6. peled
    peled
    Oct 31, 2010
    890
    10% for the night seems too much.
  7. Digikid
    Digikid
    Aug 15, 2010
    567
    What firmware you running?
  8. lotte2
    lotte2
    Jan 3, 2011
    5
    is the replacement ipad working better?
  9. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,651
    35
    4.2.1 jailbroken.
  10. SallySparrow
    SallySparrow
    Jun 26, 2010
    19
    Yes, significantly.
battery
battery keeps dying on ipad
how to drain ipad battery
ipad battery drain
ipad battery keeps dying
ipad battery suddenly draining fast
ipad keeps dying
ipad sudden battery drain
my ipad battery keeps dying
why did my why is my ipad battery suddenly draining to nothing
