iPad and WiFi Issues
Discussion in 'New Member Introductions - Site Assistance' started by Monsters, Dec 28, 2011.
  1. Monsters
    Monsters
    Dec 28, 2011
    I just got an iPad 2 and am having issues with connecting to WiFi. I see my network name, selected the network, entered my password on my iPad. Now all it does is just the little wheel turning to the left of my network name. I tried to reset my network, my iPad network, unplugged, replugged, etc... This is the same issue that I am having with my iPhone too. I have a Cisco wireless router model WRT54GS. Can someone help?
  2. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,892
    2,224
    Hi, and welcome to the forum. Good to "see" you and hope you enjoy your visit(s).
    Since you've mentioned problems with both your iPad and your iPhone, may I suggest you try resetting your router. Oftentimes, turning it off and then on helps.
    If that doesn't work, go into the Settings app on your iDevice (General > Network > WiFi > [the network you're connected to]) and choose to "Forget this Network." Once that's done, reload the network again.
    Hope this helps. Let us know how you get on.
  3. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,828
    1,306
    Hi and welcome to the Forum!
