Ipad and forum problem.
Discussion in 'iPad Help' started by soogoo, May 18, 2011.
  1. soogoo
    soogoo
    May 17, 2011
    7
    I have tried searching the forum for this but no matter how I phrase it nothing comes up although I know I am not the first to have it.
    I can't use my iPad to post on eBay forums. With my first iPad I could type in the text box but it was invisible but posted ok, now I can't even do that, the keyboard just won't come up. Is there a fix?
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
  3. soogoo
    soogoo
    May 17, 2011
    7
    Thanks for trying to help but I wasn't having trouble with an app. I use eBay direct from Safari. I have just had to restore my ipad2 from a backup whilst trying to instal 4.3 which I hoped might provide a fix, the whole thing started to go tits up so I had to abandon it. When I plugged the iPad back in it treated as a new one. Hey ho so I restored from a backup and had to reload a couple of new apps. I still can't post on the eBay forum though. Would it work with the eBay app perhaps? A net search brings up lots of people that can't post on various forums but no one seems to have a solution.
  4. DontUnderstandMyIpad
    iPad Guru
    Jan 22, 2011
    3,192
    13
    As far as I can tell, it is an ebay forum problem.
    It doesn't work with Safari, nor does it work with iSwifter, which is the common workaround for pages, which don't work on the iPad.
    The ebay app is only useful for selling, buying and browsing through items, but doesn't include the discussion board, so it won't be of much help.
    This doesn't really much, apart from realizing that it must be a universal problem with the ebay forum.
  5. soogoo
    soogoo
    May 17, 2011
    7
    It doesn't appear to be just an eBay forum problem, if you do a net search there appear to be quite a few forums where the iPad won't work. Someone posted that they had sorted it by turning off RTE but I can't find it anywhere on the pad to turn it off. Why I wonder haven't Apple addressed this?
  6. twerppoet
    iPad Legend II
    Jan 8, 2011
    21,071
    7,241
    It's most often caused by the type of editor the forum uses. Some forums, including this one, let you choose between several editors in their user options. WYSWIG editors are usually the problem.
    I looked over the eBay forum (first I knew there was one), but it does not seem to have any options to set your editor type.
    Safari seems to handle some of the WYSWIG editors a bit better than the third party browses, so if it isn't working then you're probably out of luck. At least until/if, an app is made for the forum.
  7. soogoo
    soogoo
    May 17, 2011
    7
    Oh well. One of the main reasons I bought the ipad was to be able to use it in my lounge in the evening so I was able to sit with hubby too. I spend a fair amount of time on one ebay forum in particular and it's a real downer that I can't use it in the evenings.
ipad 2 problems and fixes cant finish typing
ipad ebay problems entering text
