iPad Air WiFi Woes
Discussion in 'iPad Air Forum' started by JezzerP, Jul 29, 2014.
  1. scifan57
    scifan57
    Staff Member
    Dec 3, 2011
    27,761
    9,615
    Thanks for letting us know that you solved your problem, it could also help others with the same problem who read this thread.
  2. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,772
    6,738
    If it is interference, try looking at the other networks in your area and forcing the router to use a less crowded channel. You can't do this on the iPad or iPhone, but you should be able to find an app for the computer that will show you the wi-fi channel in your area.
    Most routers scan and pick less used channels, but they often make mistakes. You can force the router to use the channel you want and leave chance out of the equation.
