Ipad Air Jailbreak Jailbreak Problem
Discussion in 'iPad Hacking' started by prflyer, Feb 23, 2014.
  1. prflyer
    prflyer
    Aug 9, 2011
    10
    Hi,
    Have a Ipad Air (7.0.4) that was jailbroken with evasi0n. Yesterday I upgraded to 7.0.6 (thru Itunes) and tried today to jailbreak with newest evasi0n jailbreak (the one that supports 7.0.6), when I connect the Ipad the jailbreak tells me that the Ipad Air is already jailbroken and that they don't recommend doing it again. I know it's not jailbroken since I haven't run any jailbreak application after update and there is no Cydia installed.
    Should I run evasi0n jailbreak again? How should I proceed?
  2. willerz2
    willerz2
    iPad Addict
    Feb 22, 2012
    1,341
    255
    The only time that Evasi0n7 recognizes a device that's plugged in as already jailbroken is if your device is actually already jailbroken, or, you updated your iOS by clicking the Check For Updates or agreeing to update with the iTunes software auto-check prompt, and which updates your device, not upgrade. Backup your device, restore fresh to 7.0.6 in DFU mode, and re-jailbreak using Evasi0n7.
  3. prflyer
    prflyer
    Aug 9, 2011
    10
    Thanks willerz2. That's what I did, will restore in DFU mode and jailbreak.
hack ipad air without jailbreak
ipad air forum hack jailbreak
