iPad 64GB WiFi problems (cannot connect)
Discussion in 'iPad Help' started by BikerThomas, Apr 16, 2010.
  1. dpippel
    dpippel
    Jun 14, 2011
    No, it's NOT the router. It's the IPAD IPAD IPAD.
  2. Mtnmedic
    Mtnmedic
    Jun 24, 2010
    826
    20
    More often than not, local WiFi connectivity issues are directly related to the router's settings or firmware. Especially when a device attempting to connect is newer than the router. WiFi cards in routers, computers and iPads are pretty solid-state and are the last thing I'd check. Sometimes it's a driver issue or having to do with some third-party WiFi management software, but that's typically a computer problem that's not likely the case with an iPad.
    Make sure your router is updated to the latest firmware (go to "support" page of the router manufacturer's web site and find the latest software to download. They will have installation instructions.). Especially if you've had the router for more than a year or so. For a lot of folks I have helped, this is often the fix.
    Also try another channel in the router. You may be experiencing just enough interference on a particular channel to keep the iPad from connecting. Lots of ordinary stuff around the house interferes with WiFi.
    Easiest test is to go to a Starbuck's or some place that has an open WiFi network and attempt to get on there.
    Michael "Spam, spam, bacon, eggs and spam. Hold the bacon and eggs." Sent from my iPad 2 using iPF
  3. Kan601
    Kan601
    Dec 27, 2011
    Problem solved!
    I have the same problem with my IPad 2 and tried every suggestion in this thread and couldn't solve it. I've change to static IP, reboot my router, reboot iPad, reset iPad's network setting, etc but none of that solve my problem. Then found this solution work for me. I changed wireless security setting in my router from WEP to WPA then IPad 2 internet work flawlessly!
  4. Gabriel1
    Gabriel1
    iPad Legend
    Mar 11, 2011
    17,091
    747
    Glad that you got the issue resolved,thanks for letting us know the solution.
how do i conmect my 64gb first genration ipad to my wifi roter
i pad not connected to safari
ipad cannot connect to internet
ipad looks like it has wifi but cannot connect
ipad safari cannot open the page because
safari cannot open the page as ipad is not connected to the internet
safari cannot open the page because not connected to internet
safari cannot open the page because on ipad
