iPad 4 not connecting to wifi mobile hotspot on iPhone 4S
dbnjzb
New Jersey
Hi,
My ipad was connecting successfully but now it is not. It sees it and put password in but now doesn't fully connect. Any ideas?? iOS 6.0.1 on both. Thanks!
D
dbnjzb
New Jersey
I was going to reset network settings but I was trying not to...
scifan57
Regina,Canada
All that does is reset your network settings to their factory defaults. It won't cause the loss of any data on your iPad, in case you were worried.
scifan57
Regina,Canada
dbnjzb said:
I know but then I have to redo all my networks! Ugh lol
If the problem is indeed the network settings, it's either that or have no Internet on your iPad when using a WiFi hotspot.:(
D
dbnjzb
New Jersey
Ok thanks, resetting the network settings solved the problem!
scifan57
Regina,Canada
Thanks for the feedback, I'm glad your problem was solved.:)
