BlackOropher26
I was charging my iPad this morning and it finishes just now.After i unplugged it,since it says it's 100% charged and the thunder icon turned into a plug icon,i unplugged the usb cable.After unplugging it,the battery percentage turned 99% till i plugged the usb cable again..(the plug icon shows again with a 100% charged battery) then i unplugged it again and it happens again.I tried to reboot my iPad and it turned to 100% now while it's unplugged.Is this normal? should i let it check to an apple center?
I'm pretty sure i did nothing to harm the iPad,since it was in it's casing,and i have never drop nor hit it really hard.
