iPad 2 No Power
HeszXDopee
United States
Not sure if this is the correct place to post this so i apologize in advance.
About two week ago i accidentally broke the digitizer and LCD on my iPad 2 64GB. I replaced both the digitizer and LCD at the same time, please keep in mind that I HAVE fixed several ipad 2's before, from broken screens to full housing replacements. Now the problem with my ipad is that it will no longer power up... It worked perfectly before the screen broke! I figured the battery had to be completely drained so i put it on the charger for THREE DAYS and still no sign of life. I removed the logic board and used a multimeter to test the battery, it was reading .03v which i know is WAY off... My question is, which seems most likely to be at fault, Charging Port, Logic Board, Battery, or..?
YES I HAVE TRIED A HARD RESET BEFORE PULLING IT APART AGAIN.
(Hold Power and Home Button together until apple apears(never happened))
leelai
Brisbane, Australia
Hi and welcome to the Forum!
I've never heard of a problem with the battery when replacing a screen, wifi yes but not this. I have heard of trouble with the dock though.
When you did your reset did you wait at least 30 seconds for the Apple to appear....it takes longer when the iPad is off.
I've moved your thread to our DIY Section where you should receive a better response.
Please do not bump a post until 48 hours have passed......it's our Rules here as this is a worldwide Forum and sometimes it just takes time for the right person to help you,
Tutorial on creating posts on the Forum
