iPad 2 lock button and up volume bouton not working after digitizer replacement
Discussion in 'iPad Help' started by Adams, Aug 13, 2013.
  1. Adams
    Adams
    Nov 12, 2010
    7
    Ok so what did I break or do wrong here? Would this be related to where the digitizer flex cable connects into those two black housings? Or is there another type of cable that I maybe ripped or broke.
    The iPad works fine other than:
    The lock button doesn't work. Doesn't turn on or off.
    And
    The up volume button doesn't work.
    Also, my buddy said that his black case would turn it off when closing the lid. (Not a smart case). It doesn't now and I didn't think it would do that but maybe that is related. Everything else works and looks great.
    Please help me out guys/gals!? I've already ordered new double sided tape and have been looking at the different parts it could be to replace.
  2. HardMetalAlchemy
    HardMetalAlchemy
    Jul 17, 2012
    175
    13
    You should probably have another look to see if anything appears damaged. Check all cables and connectors are properly connected.
  3. Adams
    Adams
    Nov 12, 2010
    7
    I did see that where the digitizer flex cable goes into, the top of the plastic housing that kind of holds the cable down was cracked. You flip up the back sides of these so that the ribbon cable can slide in and then you lock them down. They did lock down and stay in but the again, 1 side had the plastic cracked. Would this actually cause the problems I'm having?? Please don't answer if your not absolutely sure. I don't want anyone to just say yes because it makes sense. It seemed like that ribbon seated fine even though the plastic was cracked. Is there something else that I damaged or is this port hole for the digitizer flex cable.
    I wouldn't think the digitizer flex cable has anything to do with the volume button and lock button not working. I'm thinking there's another issue I caused that's stopped the lock and volume button from working.
  4. HardMetalAlchemy
    HardMetalAlchemy
    Jul 17, 2012
    175
    13
    You may have to replace the power/mute/volume flex. It's a common problem when opening up the ipad.
  5. Adams
    Adams
    Nov 12, 2010
    7
    That helps. Thank u!
  6. Adams
    Adams
    Nov 12, 2010
    7
    Wait! Which flex cable do I need? Lol. There's 2 styles, a normal version and then a after 2012 version. My pad doesn't have that black bar thing across the top like I see some do.... .??
  7. Adams
    Adams
    Nov 12, 2010
    7
    Not flex cable, the power/volume cable.
  8. HardMetalAlchemy
    HardMetalAlchemy
    Jul 17, 2012
    175
    13
    iPad 2 2011 A1395 16, 32, and 64 GB
    iPad 2 (CDMA model) 2011 A1397 16, 32, and 64 GB
    iPad 2 (GSM model) 2011 A1396 16, 32, and 64 GB
    The numbers are on the back of the ipad.
  9. Adams
    Adams
    Nov 12, 2010
    7
    There's actually a 2012 version believe it or not and it has an updated power cable. Weird that apple doesn't show this version but you can sure order parts for it.... Figure that out.... I'm hoping mines the first version which fits both the models you listed above.
clamp that holds ipad2 digitizer broke off
how to fix nowork volume up in ipad2
ipad 2 up volume button not working
ipad 2 volume button not working
ipad 2 volume up button not working
ipad volume button not working
ipad volume up button not working
the volume button not working on ipad 2
up volume button not working on ipad 2
