Ipad 2 Home-Wallpaper does not work
Discussion in 'iPad Hacking' started by chico92, Oct 22, 2011.
  1. chico92
    chico92
    Oct 22, 2011
    5
    Hey guys, I'm sry for my english, I'm from germany...
    I have an jailbroken Ipad 2 32GB/3G and Winterboard installed.
    The problem is I can't change my wallpaper with my normal photos, it remains black. But I can change my lockscreen-wallpaper with normal photos. And i can change my home-wallpaper with winterboard themes which have wallpapers in it and i can change it to video wallpaper. But I can't change it with my normal photos. I have tried everything like restart, deinstall winterboard, clocl on user wallpaper but it still doesn't work.
    I hope you can understand me.
    Thank you
  2. Gabriel1
    Gabriel1
    iPad Legend
    Mar 11, 2011
    17,095
    747
    Hi, I've moved this to the Hacking Forum where you will hopefully get better help.
  3. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,891
    2,217
    Hi! And, welcome to the forum (your English is great, BTW - wish I had a second language...and was able to be fluent in it).
    Anyway.
    About your wallpaper(s), try this:
    Go to the WinterBoard app (either via the icon/app or via the iPad's Settings app). Pick the "Select Themes" option. One of the options you are provided, by default, in Winterboard, is "User Wallpaper." Ensure (1) that option is selected and (2) that it's above any other theme you may have loaded.
    After checking it, respring the iPad and, hopefully, you'll be able to show off your personal wallpaper(s). Good luck and let us know how you get on.
  4. chico92
    chico92
    Oct 22, 2011
    5
    Thanks for your reply!
    It does not work...
  5. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,652
    35
    So, you did what Mickey said and it still doesn't work?
  6. chico92
    chico92
    Oct 22, 2011
    5
    Yes...
    I tried to reset all my settings once and then i had some problems because it didn't begin to load, so i had to bring it to DFU mode... My jailbreaks was still their. Since then my ipad sometimes gets to the safe mode if I close apps with the home button. Today it happened again and suddenly my home wallpaper was their. But i went out of safe mode and it disappeared again...
  7. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,652
    35
    Don't use reset all settings! It wil not work.
  8. chico92
    chico92
    Oct 22, 2011
    5
    Yes I know that's why i talked in past tense.
    But some other ideas?
  9. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,891
    2,217
    It actually sounds as if you have a rogue tweak loaded from Cydia (cause you describe how you keep going into Safe Mode). Try uninstalling all tweaks you installed before you started seeing this behavior on your iPad. Then, put them back on, one by one, until you find the one that causes your iPad to go into Safe Mode.
    If that doesn't work/help, give us a list of your installed tweaks and we'll try to find the one that's probably causing you the trouble.
    Good luck.
  10. chico92
    chico92
    Oct 22, 2011
    5
    The Problem is it didn't happen before i tried to reset all my settings. So actually everything was fine with my tweaks and i did not change anything then i tried to reset and had to bring it in dfu mode... and then this problem accured. You understand?
    But the safe mode problem is not the worst. I cant change my home wallpaper thats annoying...
can't change wallpaper on ipad
cannot change wallpaper ipad
cant change wallpaper ipad2? (jailbroken)
i upgraded my jailbroken ipad but i i can't change my wallpaper
ipad wallpaper not working
ipad wallpaper settings not working
reset ipad wallpaper
reset wallpaper on ipad
themes not changing wallpaper on ipad2
wallpaper not showing ipad
