iPad 2 battery draining quicker. help.
Discussion in 'iPad 2 Forum' started by z4_ryan, Apr 22, 2011.
  1. z4_ryan
    z4_ryan
    Mar 17, 2011
    8
    My iPad2 16gb battery has been draining faster each day, I got one of the very 1st shipments in March and for the 1st two weeks it was unbelievable how long it lasted, now just messing with it for about 25 min. and its already at 90% n drops pretty quick. I have my brightness really low and on auto, I always close my apps from the multi-tasking-ish bar. It's a WiFi model, and I even have push notifications off and mail only when I request it. I can't figure out anything else to do, n I have been searching here a lot
  2. Gunny008
    Gunny008
    Nov 7, 2010
    362
    You could try letting the battery drain down to 0% and then doing a full charge to 100%.
    This may solve the issue for you.
  3. Serianni
    Serianni
    Apr 1, 2011
    43
    Hey drain it to under 20% the lower the better. Turn it off. Charge it full, and should be good to go! This should help immediately and in the future try to wait to under 20% before you plug it in. Good luck! :)
  4. jakerich
    jakerich
    Aug 12, 2010
    31
    Serianni's advice was OK for one time, or once a month, but LiIon batteries don't last as long if you routinely take them down that far. Do it once, to recalibrate the battery meter, then repeat once a month. Otherwise, keep it topped off as mucha as you can, it'll last longer.
  5. z4_ryan
    z4_ryan
    Mar 17, 2011
    8
    Thanks, but what sucks is that I have tried both of those b4 n it still drains quick, should I call Apple?
  6. z4_ryan
    z4_ryan
    Mar 17, 2011
    8
    Since I first posted the thread it has already dropped to below 45% with just simple web surfing. The 1st 2 weeks it lasted me all day and would barely b at 80-85% when I was going to bed
  7. tmno2
    tmno2
    Apr 8, 2011
    51
    Hi Ryan
    Some of the things that have not been mentioned.
    Location services
    Bluetooth
    Try looking in general settings and turn off what is really not needed.
    Also as another check, turn on Airplane Mode, which shuts down everything, phone, wi-fi, Bluetooth and location services, not that you have a phone in the iPad to shut off.
    Then turn on your wi-fi while in airplane mode to enable mail and web browsing, and see if that makes a difference.
    You have probably accumulated a lot of apps that are drawing excessively from these services.
    If those actions do not diminish the rate of discharge, then I think you should refer to Apple to rectify the problem.
    Hope this info helps
    Why does everybody, except you and I, appear crazy?
  8. wahoowad
    wahoowad
    Mar 9, 2011
    74
    #1 tip: Make sure Ping is turned off
  9. z4_ryan
    z4_ryan
    Mar 17, 2011
    8
    Thanks for the help everyone, ill try EVERYTHING tonight and hopefully it works, if not I better contact Apple in the 1st 90 days.
  10. Svenster
    Svenster
    Mar 19, 2011
    35
    Can't seem to find ping in the setting to check if on or off.
    Sent from my iPad 2 using iPF
battery draining fast on ipad 2
battery on ipad 2 drain fast
ipad 2 battery draining fast
ipad battery draining fast
my ipad battery drains fast
why does ipad battery drain so fast
why does my ipad battery drain fast
why does my ipad battery drain so quickly
why is my ipad battery going down so quickly
why is my ipad2 battery is draining quickly
