ipad 1 won't stay on home page for more than a second
Discussion in 'iPad Help' started by ravennj, Dec 7, 2011.
  1. ravennj
    ravennj
    Dec 7, 2011
    The unit won't stay on the home page screen for more than a second which it never did before. If you can force it to navigate away to another screen then the new screen has flickering down the right hand side. Has anybody seen this before?
  2. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,891
    2,217
    Well, this certainly sounds like an odd problem.
    Try the old "tried and true" trick for attempting to make the iPad behave: restart or reset. Here's how:
    Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    If that doesn't help, I'm afraid you might have a hardware problem. In that case, it may be time to take the iPad to the Apple store and let the Geniuses have a go at it.
    Good luck and do let us know how you get on.
    And - welcome to the forum!
help center for ipad ..wont stay on line
ipad screen wont stay on
ipad will not stay on
ipad will not stay on ipad homepage
ipad will not stay on page
ipad wont stay on
ipad wont stay on page
my ipad wont stay on
old ipad wont stay on b
why wont my ipad stay on
