iOS 7.0.4 -wifi connection issue
Discussion in 'iPad 2 Forum' started by ipadgizmo, Dec 25, 2013.
  1. ipadgizmo
    ipadgizmo
    Aug 28, 2011
    Hi guys.. My iPad 2 updated iOS 7.0.4. Have problem with wifi connection. Suddenly the connection off by itself.. Do you guys have same issue ? Is it my iPad or wi fi connection problem?
  2. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,892
    2,223
    Have you tried to restart or reset the iPad? To do (apologies if you know):
    If that doesn't help, try this last step...
    Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears. Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    If you've already done that, and WiFi still doesn't work - have you tried resetting or rebooting your router?
    Hopefully, one of those will help. If not, holler back and we'll take another shot at it.
ios 7.0.4 wifi
ios 7.0.4 wifi connection issues
ios 7.0.4 wifi issue
ios 7.0.4 wifi issues
ios 7.0.4 wifi problems
ipad 2 ios 7 wifi connection issues
ipad 2 wifi issue ios7
ipad 2 wifi problems ios 7
issues with ios 7.0.4 and ipad 2
wlan issue with ios 7 with ipad 2
