Input and output for an ipad
Discussion in 'iPad Accessories for iPAD 1, 2 and 3' started by markdevoll, Oct 16, 2011.
  1. markdevoll
    markdevoll
    May 26, 2011
    30
    S the headphone jack on an iPad an input output or just output? Is it tip ring sleeve or tip ring ring sleeve?
  2. stevnim
    stevnim
    Jun 10, 2011
    64
    8
    I'm hesitant to recommend any information on this other than use a browser pointed to "iphone audio jack schematic".
  3. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,733
    6,678
    If you look closely at an Apple headphone jack (with mic) you'll see it actually has four instead of the three standard rings. The last one, closest to the base, is the microphone contact. The iPad works fine with these headphones, and yes, the mic works.
    As stevnim suggests, a search for the iPhone jack pinout should get you diagram. I used to have a good link, but it seems to have gotten lost.
change ipad output to input
inputs and outputs of an ipad
inputs and outputs of ipad
ipad 2 inputs and outputs
ipad input
ipad input and output
ipad input output
ipad inputs
ipad inputs and outputs
ipad outputs
