Infinity blade crash
Jonathan146
New york
leelai said:
Give these steps a try-
Do the four finger swipe up to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now. if not a restart is in order.
When your iPad begins to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
My iPads jail broken, so step 2 and 3 won't work
Mickey330
Western NY state (USA)
Being jail broken doesn't prevent you from doing a reset or restart. The thing you want to stay away from is restore - that's the thing that'll wipe your jail break.
Restart is merely turning off, then on, while reset is Apple's fancy way of saying "reboot." Neither of them bother a jail break because, even if you are tethered, it's a simple matter to do a tethered reboot.
So, try these two. They may help your game crashing problems.
Wilf
The four finger swipe up and terminating of the active apps, I think, did the job...thanks Jonathan146! Everything else, I tried before...that, did the job... many many thanks...everyone else who has this same crashing on load up problem, take notes!
