iBook & photo problems
Discussion in 'iPad Help' started by Balonge, Nov 11, 2011.
  1. Balonge
    Balonge
    Apr 28, 2011
    Hi, can anyone help. I was half way through a book that I bought through iBooks. I opened up the app and that book plus 2 others disappeared. They don't seem to be in iTunes and I can't open the store through iBooks to even check if it acknowledges that I have
    Ur chased these books previously. When I try to open the store it shuts the whole app down.
    I've also synced a heap of photo albums. The albums are all there but they are all empty except the photos I've taken on the iPad or downloaded straight to the iPad - anyone know what's going on there????
  2. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,733
    6,678
    Clear: With the problem app closed, double tap on the Home button to get the multitask bar. Tap and hold on any icon in the bar until they jiggle, then tap the minus sign on the problem app. This will remove it from RAM and insure a clean start the next time you launch the app.
