I Pad Won't Power Up and Won't connect to I Tunes
dikamp
Montana
This happened a few days ago and I was able to connect to I Tunes and repower. But now I am staring at a black hole.
D
dikamp
Montana
I just tried a cold boot by holding down the Home button and the on off switch for more than 10 seconds a finally the apple came on and because it was connected to the computer, it is now displaying a I Tunes logo and the end of the USB cable. I Tunes suggested if I was having trouble to restore factory settings. So I'm doing that. Any down side?
maddoc4277
rock hill sc
Initially, this sounds like a depleted battery. Be sure that you have a fully charged battery.
Being connected to the itunes, you shoud be able to have been auitomatically backed up.
By restoring, you will lose the data you entered: photos, music, contacts, notes, apps... but they will all be backed by by the itunes and whatever contact list you are using.
My suspiciaon tho is that the "black hole" is that the battery is/was critically low... put it on its charger for 6-8 hours, see what happens beofre you do anything.
just my 0.02
davis
