Hi all can anyone pls tell me how to upgrade my JB ipad1 3.2.1 to 4.3.5. Everytime i use restore or update it shows me a error code: 3194 Thank you
You can only install 4.3.5 if you have saved blobs for 4.3.5 for your iPad1. Without these your only option is 5.0.1. To see if you have them saved, use this tutorial - http://www.ipadforums.net/jailbreak...01-how-save-your-shsh-blobs-tinyumbrella.html If 4.3.5 does not appear in the list when you are finished then there is absolutely NO WAY to install 4.3.5. If you do have them you can press "Start TSS Server'' and install the firmware. We have a guide on upgrading a JB device here - http://www.ipadforums.net/jailbreak...des/26399-how-upgrade-your-ios-jailbreak.html
