How to eliminate notification sound
Discussion in 'iPad 2 Forum' started by Compiler777, Jun 6, 2014.
  1. Compiler777
    Compiler777
    Jun 9, 2012
    28
    Using IOS7.1.1
    My ipad makes a sound every time a notification occurs. I can't seem to find a setting to turn that feature off.
    I just want the sound off when a notification happens.
    What am I missing?
    Mel
  2. J. A.
    J. A.
    Staff Member
    Nov 11, 2012
    18,985
    11,594
    In Settings - Notification Center open the app/s that you hear every time. Then you can find something like "Sound" or "Alert sound", which has to be disabled.
    Also, if your Side Switch is set to mute, enable it (it shows the red part then) to mute alert sounds. If it's not set to mute, open the Control Center and press the Mute button there.
    Hope that helps.
  3. giradman
    giradman
    iPad Wizard
    Apr 26, 2011
    6,980
    6,226
    Not sure that there is a 'global' setting that can mute all sound on your notifications; but you should be able to disable sound for the specific apps that may be the most annoying to you. First, try going to Settings -> Notification Center, then select the app(s) that you want to mute the sound and tap on each - 'Sounds' or 'Notification Alerts' should be an option that can be changed; or go to Settings -> Sounds - there 'Alert Tones' can be usually set to 'None' - let us know if this helps. Dave :)
  4. Compiler777
    Compiler777
    Jun 9, 2012
    28
    Thanks. Issue seems to be resolved. There seems to be no global setting
    Mel
  5. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,872
    6,897
    Mute is the closest to a global setting; however it is more global than you probably want, since it affects all system sounds, not just notifications.
    Mute does not affect music apps or most other apps. It's meant to suppress unexpected sounds, not the what you've started playing intentionally. There are exceptions, because not all app developers implement it correctly.
eliminate sound on i pad
how to eliminate notification sounds on apple i pad
how to eliminate notification when using apple music
