How does IPAD 2 deal with 3G and Wifi connection
Discussion in 'iPad 2 Forum' started by mamurao, Jan 3, 2012.
  1. mamurao
    mamurao
    Nov 16, 2011
    15
    First off, thanks guys for this awesome IPAD forums we have here very informative and i'm impressed, more power. It made my life easier to be an IPAD user.
    Anyways I have a 16Gb 3G IPAD2 and have data plan.
    My question is how does the IPAD2 decide on which one to use if both 3G and Wifi network is available? in the Android specifically the Samsung Galaxy S tablet it switch off the 3G once a allowed WiFI connection is connected.
    if you can advice
    thanks :thumbs:
  2. mamurao
    mamurao
    Nov 16, 2011
    15
    I found this link, https://discussions.apple.com/thread/2444104?start=0&tstart=0
    i
    experimented and on my left hand corner it says the provider name "Rogers" and the Fan symbol no 3G. which means Wifi is connected not the 3G .
    And when i was not connected to the wifi the symbol "3G" was on the top left corner.
    is that correct?
    thanks
  3. jsh1120
    jsh1120
    iPad Addict
    Jan 27, 2010
    1,292
    87
    Yes, that's correct. Like many Android devices, the iPad will use a wifi signal if it's available (and obviously you have wifi turned on.) Otherwise, it will try to find a 3G signal.
  4. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Worth noting that the iPad (and iPhone) will always prefer a wifi connection over 3G even if the wifi router is not connected to the internet. This can lead to some head scratching if you connect to a hotspot that, for whatever reason, does not have an active connection to the outside world...
does ipad use wifi before 3g
how to connect ipad2 to internet without wifi
how to see if my ipad 2 is 3g or wifi
ipad connect to both wifi and 3g
ipad does nto use wifi before 3g
