How do I SSH??? Need help please!!
Discussion in 'iPad Hacking' started by blac2k8cs, Feb 8, 2011.
  1. blac2k8cs
    blac2k8cs
    Feb 2, 2011
    25
    How do you SSH into your device? I know thats a newb question and I have been doing my own research but can't seem to figure it out/make it work. I downloaded the trial version of CuteFTP and have tried to set it up with my device but I cannot make it work! What app do I need on my ipod/ipad to make this easier to do? I need to change permissions on some files and it's driving me crazy. Any help you or anyone can provide would be greatly appreciated.
  2. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    You install OpenSSH from Cydia. That will enable ssh access on your iPad. By default the credentials are user name "root" and password "alpine". Once you have this installed you should be able to connect using cuteftp from your desktop.
  3. blac2k8cs
    blac2k8cs
    Feb 2, 2011
    25
    It worked, Thanks for your help!
  4. iPadCharlie
    iPadCharlie
    iPad Super Guru
    Jun 19, 2010
    4,231
    7
    I know the question has already been answered, but I use the PuTTY program --
    PuTTY Download Page
can't ssh into my ipad?
cannot ssh ipad air
cant ssh into ipad 2
how do i ssh into my 4th gen ipod touch
how to ssh into your ipod 4th gen
ssh
ssh into ipad4
