Home button problem
Discussion in 'iPad Help' started by Wbtt, Jan 12, 2011.
  1. Wbtt
    Wbtt
    Jan 1, 2011
    Has anyone had problems with the home button not working right all the time? When I click down on the button nothing happens...even if I hold it down, nothing..then I have turn off the IPad in order to go to a different app...
  2. maclizard
    maclizard
    Jan 15, 2011
    8
    Yes, I have the same problem! I just bought my iPad last night and I have done the sync with iTunes including the latest update from Apple. I cannot get the home button to work properly!!!
  3. gentlefury
    gentlefury
    iPad Guru
    Mar 15, 2010
    2,615
    7
    I had that problem with my first iPod Touch...I brought it back to the store and they swapped it out on the spot.
  4. flick67
    flick67
    Sep 5, 2011
    Yep I'm also having problems with my pad home button which iv had now for near 2 years .
  5. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,828
    1,307
    I find if I have a problem with my home button, I try a few things. First, I shut down everything that I've had opened by pressing the home button twice to bring up my multi task bar at the bottom. This will show you all the apps you have had running at some point. Long press one of the apps, they will start to jiggle and a minus sign in red will appear at the top left hand side. Press these minus signs, this will close the apps but dont worry it doesnt delete them. Then see if this makes a difference, I understand if you are having problems with the home button it may be difficult to bring up the multi task bar. So onto the next step which is to turn off your iPad. Long press the power button at the top right hand side, this will bring up a slide to power off, do this, the screen will go blank with a Whirly in the middle. This will take a few seconds to disappear. Turning your iPad off regularly helps everything to reset and you should do this. After the whirly has disappeared wait a few extra seconds then long press the power button for a few seconds until the apple logo appears and wait and your screen will reappear. This will solve the home button problem for some of you. If it hasn't you should do a reset. Hold the power button and the home button simultaneously, this will take a few seconds longer than normal but what will happen is the slide off feature will appear and disappear, keep holding the buttons until the apple logo reappears. This is a reset and now you should be good to go.
  6. flick67
    flick67
    Sep 5, 2011
    Thanks leelai I'm gonna try all as I'm sure your solution will help . X
  7. apple2011
    apple2011
    Aug 23, 2011
    128
    Maybe that can help you at some time. While it will be better for you to contact the apple or go the native apple store. You can get good answer there,maybe a replacement or some fix. That can be fast and effective.
home button on ipad not working
ipad 2 home button problem
ipad air hold button issues
ipad button not working
ipad button problems
ipad home button not working
ipad home button not working all the time
ipad home button problem
problem with on button on ipad
what to do when ipad button problems
