LynEdwards2004
- Joined
- Nov 11, 2012
- Messages
- 4
- Reaction score
- 0
I have two Apps which won't download. They just say waiting...I can't delete them in the usual way. Any ideas?
ewoodson said:It could be the update. If you haven't updated, you may need to. iMovie will not update without the new iOS, for example. If you have updated and it still has the issue try a hard reset and then try to go back into the app store to update.
LynEdwards2004 said:Any risks?
