Help!
Discussion in 'iPad Help' started by shideh, Jun 30, 2011.
  1. shideh
    shideh
    Jun 12, 2011
    8
    Hi! Like many of you, i'm new. My iPad2 just froze when i had an app up. The whole picture is frozen and the home button doesnt work. I am trying synch it by iTunes but it's taking forever and sats synch step 1of 3. The iPad feels warm. What to do??? Help!
  2. SweetPoison
    SweetPoison
    iPad Legend
    Jun 20, 2010
    14,913
    133
    Try holding the power button and the home button down at that same time, until you see the Apple logo.
    Let it reboot.
    See how that works for you and get back to us!
  3. stuhrer
    stuhrer
    Jun 11, 2011
    13
    I had a frozen iPad once. I solved it by shutting it down completely by pressing the Home- and Sleep/Wake-button for a few seconds. If it doesn't work immediately, try it several times. I hope it helps.
  4. shideh
    shideh
    Jun 12, 2011
    8
    iPad 2 FaceTime problem
    My boyfriend and i bought our iPad 2 ( one each) mine is working perfectly. I could connect to FaceTime without any problem but his wont allow him. The wired thing is that we are using the same wifi at home, both are on line and the internet connection is working BUT when he tries to logg in, it says FaceTime could not connect you check your connection but he is Co. me Ted, just like me. Could this be something in his iPad? His email adderas is correct and we have confirmation. We can see the wifi connection is working yet somehow FaceTime can not get access. :confused: vertikal frustrating. I have asked you in the passed for other iPad problems. Please help us!!!!
