1. becky098
    becky098
    Aug 3, 2013
    I can't type anything on habbo hotel on iswifter
  2. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,828
    1,306
    Hi and welcome to the Forum!
    Had you previously been able to access this site through iswifter?
    When an app behaves strangely it is best to close it completely and then relaunch it. From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar. These are all the apps that you have opened at one time. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it, now press the home button to return to your screen. It's also a good idea to close all these apps, as it helps the iPad run smoothly. See if it is now working.
    I have noticed an App for Habbo....I don't know this site at all but this app may be useful.....check it out.
    https://itunes.apple.com/au/app/app-for-habbo/id672517903?mt=8
    Tutorial for our App
    http://www.ipadforums.net/new-membe...sistance/107524-ipad-forums-app-tutorial.html
    Tutorial on creating posts on the Forum
  3. scifan57
    scifan57
    Staff Member
    Dec 3, 2011
    27,757
    9,615
    Welcome to the iPad forums Becky, the largest and best iPad forum anywhere, with over 298,000 members worldwide. Many of our membership volunteer their time to help their fellow members with answers to their questions and solutions to their problems. If a search of the forums doesn't provide the answer you need, don't hesitate to post your question in the appropriate forum. We also have this tutorial to help you get full use from the iPad forums app.iPad Forums App Tutorial We ask that all members take the time to review the Forum rules before posting.
