Help With WiFi
markism3
I have version 4.3.5 OS. My iPad 1st gen lags on Wifi. I have no problems with my iPhone 4. Any suggestions?
Tx
richsadams
NW Left Coast
Welcome to the forum! There are a lot of great people here willing to lend a hand anytime. Often using the search feature (in the toolbar at the top of every page) will lead you to the answers you're looking for. If not, feel free to post a question in the appropriate area.
Please take a moment to view the information linked below my signature to get the most out of your iPad as well as our forum.
BTW, I moved your post to the iPad Help area where you're likely to get a better response to your question.
Welcome again and enjoy!
Tim SPRACKLEN
One of our Admin Staff, Colin wrote this....
This has resolved many issues and worth a try.
- Sometimes after you perform a upgrade *the iPad or iPhone wifi or 3G speeds *may be slow.*
__________________
Cheers
Col
col.bris, Brisbane Australia
Forum Rules. Please Read.
