help with set up
Discussion in 'iPad Help' started by mattd285, Jun 16, 2010.
  1. mattd285
    mattd285
    Jun 16, 2010
    having nightmare with set up of i pad. bought in florida 2 months ago brought home, still not able to set up. must have tried 50 times to download itunes but no further instructions are forthcoming. the ipad just shows a picture of the cable and an itunes logo. what do i do next?
    about to bin the thing or hide it on the shelf.
    everywhere where i researched so far says its supposed to self sync?
    please, before i smash it up.
    regards
    matt
  2. Matth3w
    Matth3w
    iPad Ninja
    May 26, 2010
    2,017
    Are you serious? Plug the iPad in, turn it on, and start up iTunes. You've been banging your head against the wall for two months and didn't think to type into Google "how to set up your ipad"? LOL
    Here's the first result:
    How To: Set Up Your iPad the Right Way
    And there are a million other results, videos, and articles thereafter.
  3. mattd285
    mattd285
    Jun 16, 2010
    looked at the set up guide, nothing like that happens on the ipad!!
    nothing happens when i plug it in at all. just a pic of power cable.
    regards
    m
  4. Matth3w
    Matth3w
    iPad Ninja
    May 26, 2010
    2,017
    Did you charge it and turn it on?
  5. mattd285
    mattd285
    Jun 16, 2010
    am i missing something with turning it on?
    i know how to turn off, ie top and bottom button same time, slide to power off etc.
    its fully charged.
    regards
    m
  6. Matth3w
    Matth3w
    iPad Ninja
    May 26, 2010
    2,017
    Hold in the lock button until it turns on. The Apple logo will pop up.
  7. Undaunted
    Undaunted
    Jun 19, 2010
    Same Problem...
    On my Ipad I have the same problem. I get the image of plug in to iTunes, eventually I can get it to make the new item found sound and then a pop up for "Import pictures and video Wizzard" appears. I am not sure why this appears? Help, what to try next.
    btw I do have a current iTunes open when this happens.
  8. ipadfanatic
    ipadfanatic
    Jun 3, 2010
    134
    I checked my calendar and it's not April fools day but please tell me this is a joke. Your iPad comes with 90 days of free support
  9. Matth3w
    Matth3w
    iPad Ninja
    May 26, 2010
    2,017
    I'm pretty sure he wasn't joking. Notice after I told him how to turn it on he never came back.
  10. col.bris
    col.bris
    Staff Member
    Mar 25, 2010
    5,888
    710
    Just a question have you downloaded iTunes to your PC or Mac from Apple.com. If not do so then after you install then launch itunes ok then plug in the iPad and follow instructions
    If non of that is working you either have an problem with your main computer or a problem with the iPad without detailed information it is hard for us to advise.
    The bottom line it works 99% of the time providing you followed the above directions. If alleles fails go to an Apple store and have it checked
    Col
assistance with pad instructions
help to get my new apple i pad on
help.apple.com/pad
i pad directions
i pad help
i pad start up instructions
ipad start up instructions
ipad startup directions
ipad startup instructions
www.help.apple.com/pad
