Help with itunes
eddieg
United States
I just updated my ipad air to ios9 through itunes the update worked but when it finished a window came up saying to go to itunes.com to download the latest version of itunes. I have version 12.1.2 when i click on help and check for updates it says 12.1.2 is the current version. I cant view my ipad on itunes without having 12.3 i believe. How do i get 12.3?
E
eddieg
United States
I did that and it says the version of iTunes 12.1.2 is the current version.
giradman
North Carolina
Well, I'm assuming that you are running iTunes on an Apple computer, i.e. laptop or iMac? Which one (model/year) and what OS X is installed. I own a 2013 MBPro and my current iTunes version is shown below (blue arrow) - Dave :)
giradman
North Carolina
Windows 7
Thanks - I was not sure which computer & OS you were using (may have missed it, sorry) - seems like the same version is for Windows too, at least from the screen capture shown below (LINK). Hopefully, others using Windows will 'chime in' to help - good luck! Dave :)
