Help with iphoto
addiosamigo
Using this guide http://www.redmondpie.com/how-to-by...-on-iphone-ipad-ipod-touch-running-ios-5.0.1/ I have been able to download and install iPhoto, but it crashes after updating the library, anyone know why this is? When using the camera connection kit my iPad is displaying loads of weird file types that are unrecognised, I think this may have something to do with it but I am using pwntunes so guessing those files are relating to that? iMovie, pages etc works fine doing this but iPhoto will just not work. All apps have been officially purchased so its nothing to do with that.
Milton-Freewater, OR
Did you upgrade to iOS 5.1 first? iPhoto probably uses features/APIs only present in 5.1.
I've seen similar articles about getting iMovie and iPhoto on an iPad 1 running iOS 5.1. I have yet to see an article on how well they run. Slow, I would guess, and best if used right after a restart.
addiosamigo
addiosamigo
No as there was no need to be able to install iMovie.
Im guessing you suggestion is why it's not working!
f4780y
Troon, Scotland
Yes, there's a reason they are 5.1 only, and whilst it appears you can hack iMovie and it will run, iPhoto is probably a step too far. It's never a good idea to do this unless you can be sure of what is happening under the covers.
addiosamigo
addiosamigo
apparently when an app is downloaded if it has a software restriction it will do a check on the systemversion.plist, hence why when you edit that file the AppStore says yes it's 5.1 ok to install, but I hear what your saying editing any system files is risky, especially when the 5.0.1 iOS window has now closed!
f4780y
Troon, Scotland
I see there is a fix in Cydia tonight which is supposed to fix iPhoto running on JB 5.0.1. You might want to try it out...
addiosamigo
addiosamigo
awesome thanks! and it works!
f4780y
Troon, Scotland
Cydia has a really good search you know ;) iPhoto would be a good thing to try :D
But if you really need to be spoon fed, the package is called "iPhoto501Fix". Enjoy.
gresh14
I did try searching, sorry I put you through all that trouble of posting it.
dstuttgen
Oconto, WI, USA
Using this guide How To Bypass iOS 5.1 Restriction When Installing iMovie v1.3 On iPhone, iPad, iPod touch Running iOS 5.0.1 | Redmond Pie I have been able to download and install iPhoto, but it crashes after updating the library, anyone know why this is? When using the camera connection kit my iPad is displaying loads of weird file types that are unrecognised, I think this may have something to do with it but I am using pwntunes so guessing those files are relating to that? iMovie, pages etc works fine doing this but iPhoto will just not work. All apps have been officially purchased so its nothing to do with that.
Oh the joy! I just updated following the tutorial at Redmond Pie and dl'd iPhoto and installed the fix from Cydia. Fabulous! It worked for me. I have read that this will not survive a sync in the iPad 1 and am wonderind if, since I edited the .plist in iFile, will this now survive a sync? Thanks to all the folks who bring us all this jailbroken goodness!
Cheers, Dan:eek:
Gzoladz
D
This is great...that red 1 on the app store was doing my head. Imovie updated :)
Gzoladz
D
Bad news...a couple of hours after I did this, my ipad went mad and started like trying to restart without achieving it...long story short, I had to upgrade in tears to 5.1...I am devastated...
f4780y
Troon, Scotland
Folks should take heed. The two users above this post have both lost their jailbreak as a result of this hack. Don't do this unless you understand what the consequences are and don't blindly click "Confirm" in Cydia without reading what it is about to do...!
Corona is dependant on IOS 5.0.1. Cydia will try to remove it with disastrous consequences, if you hack your iPad2 to make it think it's got 5.1 on it!
iPad2 jailbreaks are precious things. You need to look after them! ;)
