Help With Camera Connection Kit
Discussion in 'iPad Help' started by Dave, May 21, 2010.
  1. MikesTooLz
    MikesTooLz
    iPad Ninja
    May 7, 2010
    2,361
    20
    I just tried a couple more SD cards here is the results from them.
    SanDisk 2Gig = Not supported
    SanDisk 1Gig = Not Supported
    SanDisk 4Gig SDHC = Not Supported
    SanDisk 1Gig Ultra II = working
    Eye-Fi Pro SDHC 4Gig = Working.
    PNY 1Gig = Not Working.
    #21 MikesTooLz, Jun 1, 2010
  2. maryinredding
    maryinredding
    May 4, 2010
    164
    I'm using a PNY SDHC 8 gb card in the reader. It brought the pictures only from my camcorder. I don't think the ipad supports video from camcorders. I don't remember reading anything in the instructions about it.
  3. serexa
    serexa
    Oct 27, 2010
    I had the same problem with a Kodak SD card. But solved the problem from a tip I found on the net.
    Just create a folder ın the card named DCIM. And put all your photos into this folder and tada!
  4. teacher12
    teacher12
    Sep 6, 2011
    I have a SanDisk SDHC 16GB card and it wouldn't work when I moved folders of photos over. I put the folders in the DCIM folder and it still wouldn't work. Then, I moved all of the photos into the DCIM folder (no subfolders) and the ipad found all of them.
camera connection kit for ipad doesn't work
camera connection kit for ipad doesn't work not support
camera connection kit ios7 not work
how do i get my shark camera connection kit ipad instruction
ipad camera connection kit troubleshooting
ipad camera connector not supported
ipad sd card reader trouble shooting
ipad wont read pny memory card
troubleshoot sd card reader to ipad
