Help please, iPad 2 won't post on some forums
Womble62
Hello newbie here, help required. When I use one of my forums and I try to post a reply, the keyboard either fails to appear or it appears and immediately shuts down safari. Meaning I can't post on this particular forum. Is it a forum problem or an iPad problem? Thanks in advance
Tim SPRACKLEN
W
Womble62
Hi, thanks tried that and the problem still persists :-(
Tim SPRACKLEN
Do you only have this 'shutting down' problem when trying to post on Forums or other websites, or does Safari shut down on other occasions? I'm suprised that resetting the iPad didn't fix the problem - it's a not-uncommon problem and powering down the iPad usually always works.
So let us know if Safari shuts down on other occasions - i.e. it's a problem solely related to filling in forms etc....
W
Womble62
It only happens on one particular forum as soon as I tap in the reply box, Safari either shuts down immediately or the keypad pops up then safari shuts down
Milton-Freewater, OR
Check the setting (options) on the problem forum(s). Most will offer you a choice of text editors. The iPad has trouble with some of the WISIWYG editors. If you can change to another, do, and see if that works for you.
W
Womble62
There are no options to change. It works fine on my iphone4
Jeeper
Michigan
Do you have "accept cookies from visited" turned on in Safari Settings?
Well, you could check out the Tapatalk or Forum Runner apps and see if your forum(s) support one or the other. That would put an end to needing to go to the website for most tasks.
