help!!! my ipad2 glass case has a crack...
Discussion in 'iPad 2 Forum' started by alvin2rija, Apr 27, 2011.
  1. alvin2rija
    alvin2rija
    Apr 22, 2011
    17
    10
    how can i best ensure that the crack will not get bigger? i am not sure that cracks is included in the warranty but right now my primary concern is to make sure that the crack does not get bigger... any suggestions? please help.. thanks....
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    Several members have reported that Apple take a very lenient view of screen cracks and will usually replace the iPad free-of-charge. It can't help to see if your local Apple Store will do this.
  3. DontUnderstandMyIpad
    iPad Guru
    Jan 22, 2011
    3,192
    13
    Yes, definitely talk to your local Apple Store first, if they don't replace it, you might want to consider the use of a screen protector.
  4. alvin2rija
    alvin2rija
    Apr 22, 2011
    17
    10
    i am in the philippines and the local apple store does not yet support ipad2 when i called them... they still do not have any instructions on the repairs and they informed me that it will be released in a week and i should call their engineering department to check when it is officially launched... right now,i guess, my best bet is to buy a screen protector, until i can talk to a representative...
apple ipad repair glass manila , philoppines
can a crack in the ipad2
can an ipad2 screen be replaced
can glass on ipad be replaced
can the face of an ipad be replaced
can the glass on a ipad be replaced
can the glass on an ipad be replaced
forum my ipad broke the mirror where i can repair this in manila
ipad 2 screen replacement philippines
ipad screen repair manila
