MorrisTheCat
I have searched here but I did not find any other posts. I use and relay upon Mic Check having purchased the full version to get rid of the popup adverts a while ago. It has been a very handy tool allowing me to record very high quality audio off the mic and email or Dropbox it.
I have now updated my iPad Gen4 128GB to iOS7 a few weeks ago as a number of my other high cost Apps simply would not work without it. One reason for a 128GB was to have ample space for audio files in the App.
Now however I find Mic Check for iPad is no longer making a viable .mp4a file that can be played or uploaded to Dropbox. The recorded audio file details appear in the list but they won't play. Bit annoying because some are important projects of mine from a week ago and it's only now when I tried to do something else with them I discover they are compromised... Note: I can still play audio files dated back to 2013 however!
I have tried the usual of reinstalling the App from the Cloud. At the App Creator's web page it's still being advertised as a Product but here's the crazy thing. Clicking on the AppStore Link you're sent to the Store all right but for me it's just a White box of Nothing! That says something, plus at time of writing this a search on the Store it does not appear!
I paid good money for this App. It no longer works and something is going on to block me using it to the point it's of any use. You would think out of professional courtesy there would be an apology or explanation from Apple, not a white square.
Can anyone suggest what is happening please. I have emailed the App Creator but I expect a reply will take a while if indeed I ever receive one.
Here's a link to the App Creator's advertisement:
http://www.appato.com/kellen-styler/mic-check-recorder-for-ipad/
