okay so i need help i bought my ipad brand new back in February i used it for about a month on and off and then it just got to the point where i didnt have time for it i played a few games and did this and that so i decide to put it up as i have a 2yr old and a 200lb st bernard and didnt want it getting damaged i kept it in the box turned off so it wouldnt get ruined and now i took it out today to play around with it and now it will not come back on???HELP i love my ipad ive just been so busy its sat in the closet..and id like to bring it back to life,any one have and advice on what i can do?? thanks am
The easiest first way to try to solve ‘unexplained’ or ‘unusual’ problems with the iPad are:- Force the offending app to close. If you have iOS 4.2 or 4.3 double-press the ‘Home’ button to bring up the multi-task bar at the bottom of the screen. Press *and hold* any icon until they start to ‘jiggle’. Then tap the top left-hand corner of the app that you want to close. It will ‘disappear’ from the list. Don’t panic - you’ve not deleted it, just closed it. Now tap the Home screen and the multi-task bar will disappear. Re-open the iPad’s app and see if the problem has resolved itself. If not, it’s on to possible solution number two!! Restart the iPad. Press *and hold* the Power button. After a couple of seconds a slider control will appear asking you to confirm that you really want to switch the iPad off (this is all you’ll be doing). Slide the control to accept. A rotating white ‘bezel’ will appear in the iPad screen as the iPad powers down (it takes a few seconds, just like it would if you were shutting down your PC). When the screen of the iPad has gone completely blank, press *and hold* the Power button for a couple of seconds until the white Apple logo appears and the iPad starts to power up. This takes several seconds, so be patient. During the power up the automatic screen orientation function is disabled, so don’t panic. A few seconds before the power up is complete, the iPad plays a little ‘jingle’ and then you’re back to the Home screen. Restart the iPad’s app and see if the problem persists. Apple (and Forum members) recommend that you power down your iPad at least once a week, just as you might regularly completely switch off your PC. The normal procedure of just briefly pressing the Power button of the iPad merely puts it to ‘sleep’. Most Forum members have found that one of the two methods I’ve mentioned here cure a whole bunch of unexplained problems and are an easy first step to resolving most anything that happens on the iPad. Tim Scotland
Even though you turned it off before putting it up the battery is probably completely drained. Plug it into the charger for at least a couple of hours and let the battery catch up. If it still won't turn on after that, get in tough with Apple CS.
Considering they can't get the iPad to turn on in the first place I don't think turning it off will help
For future reference, Li-Ion powered devices should be stored with the batteries at around 80% full. These batteries have a low self-discharge rate, and should easily last 3 months or longer of properly stored. Can you remember what the figure was when you stored it? And are you sure you powered it down completely?
If charging it a few hours doesn't work, Apple should replace the battery under warranty. I'd be really surprised if they didn't. Support Our Troops! This post was Tapatalk approved Sent from wherever I'm at right now via my Apple tablet
