Help !! How to sync folders
Discussion in 'iPad Help' started by sugata_datta, Dec 19, 2011.
  1. sugata_datta
    sugata_datta
    Dec 19, 2011
    6
    Please help me !!! I have a number of .doc, .xls and .ppt files in various folders in my pc .. I want to sync the folders with my IPad2. At present, I find that only FILES can be synced, NOT folders. Its too much of a pain to sync files as it creates long unwieldy lists of files. If I could sync folders, then they would be much more organised..
  2. twerppoet
    iPad Legend
    Jan 8, 2011
    19,861
    4,982
    GoodReader can sync entire folders.
    Though my real recommendation is to get a DropBox account and the install the app on both your iPad and computer. Then you can drop the entire folder into the synced folder on your computer, and not too long after it will be available via the DropBox app on the iPad. Favorite files can be stared, so that they are always available.
    GoodReader can also access DropBox, and upload/download entire folders to it, if that is what you decide you need. GoodReader will view, but not edit, most of the files you've mentioned.
    Many of the better Office compatible apps also offer direct access to DropBox, making them ideal way to interact with your files via DropBox.
    You might be getting the idea I'm pushing DropBox here, and I suppose I am; but it's one of the most popular services on the forum, and useful for many things. And GoodReader is probably only a few posts less popular.
    Here are some links to reviews of the Office apps I mentioned, just in case that was you next question. Pages, if you are curious, does not work directly with DropBox, but there are workarounds.
    Compare iWorks, Office 2 HD, Documents to Go, QuickOffice by richsdams
    http://www.ipadforums.net/new-member-introductions-site-assistance/22431-hi-all.html
    Office Apps Comparison by RedCoil (details and examples, very long)
    http://www.ipadforums.net/iwork-forum/36629-office-app-comparison.html
    About QuickOffice, mostly about spreadsheets
    http://www.ipadforums.net/ipad-apps/55182-just-purchased-quick-office-hd.html
  3. sugata_datta
    sugata_datta
    Dec 19, 2011
    6
    Many tks for your reply. I have, indeed, started using Dropbox. However, I find the following problems while using dropbox on the IPad2: 1. If I am not connected to internet, the Dropbox files cannot be accessed. 2. The solution to this would be if I could SAVE the folders / files in the IPad and while syncing the folders from my PC, if I could sync the files / folders in the saved files, rather than in the Dropbox. Yes, I know that I can save the files by marking them "favorites' but that would entail marking so many files (I have over 300 files in the dropbox) one by one, each time I sync them with my PC. Moreover, I cant mark a folder as a Favotite - only files. Any solutions ? Would be grateful...
  4. twerppoet
    iPad Legend
    Jan 8, 2011
    19,861
    4,982
    GoodReader can be used to download and store files on the iPad. It is best for reading and annotating PDFs, but It will view many other formats. It will even connect to DropBox and download entire.
    Even if you decide you don't want to use GoodReader this way, it is a very handy app to have around. It has a veritable Swiss army knife of features.
    The other option is to get a specialized app for each type of file you want to work with. Many of them have both local storage and DropBox access. One of the office compatible suites like Documents to Go or QuickOffice would be overkill for view only, but should work the way you want file wise.
    #4 twerppoet, Jan 7, 2012
  5. sugata_datta
    sugata_datta
    Dec 19, 2011
    6
    I want to know how to attach multiple files to emails. Also can u tell me how to copy files from Pages to Dropbox ?
  6. twerppoet
    iPad Legend
    Jan 8, 2011
    19,861
    4,982
    If it's pictures, just use the Photos app. You can attach up to five pictures to an email in Photos.
    Doing multiple attachments of different file types is difficult. If you use Open In or another method to copy them all to GoodReader, you can send multiple attachments that way. Most of the time I recommend uploading the files to a cloud service like DropBox or Box.com and then emailing the share links instead. Not only is it easier to to on the iPad, but it makes for faster email and the convenience of choosing when to download on the receiver's side.
    There are a couple of services that will give you WebDAV access to DropBox. DropDAV is nice, but has a monthly fee. SMEStorage is another, and while it isn't as neat a solution as DropDAV you can use it for free. The iSMEStorage app costs $4.99. It's not required, but I think it is worth it. You can find several (more complete) posts in the forum on SMEStorage; just use the custom Google search at the top of the website.
    I also like to use Box.com. It has WebDAV, but not the computer syncing of DropBox. Between it, DropBox, and iSMEStorage I can do most of my file sharing directly from the iPad.
  7. sugata_datta
    sugata_datta
    Dec 19, 2011
    6
    Thanks for the reply. How do I upload files from Pages to Dropbox? I find that only certain types of files, like photos, etc can be uploaded to Dropbox. But I would like to upload files made thru Pages or Numbers to Dropbox. How do I do that ?
  8. twerppoet
    iPad Legend
    Jan 8, 2011
    19,861
    4,982
    The iWorks apps have a WebDAV option when importing and exporting files. The last half of my previous post was dedicated to getting DropBox to work with WebDAV, which will also let you use it with Pages (indirectly).
    You can select and import/export Pages files from the Documents page
    or you can export them using the wrench icon when the document is open.
    You'll find all the info you need on the SMEStorage's site, or if you can ask and I'll help some more: But you really should read and understand their service, so that you can get the most out of it.
  9. JFrazier
    JFrazier
    Jan 26, 2011
    42
    Help! Does anyone know why my photos and videos all show up upside down when I email them? They are correct before I send, but come in upside down when I receive. I am having the same issue with my iPhone. Cannot figure out if it is a setting or what? Thanks for the help!
    Julie
  10. twerppoet
    iPad Legend
    Jan 8, 2011
    19,861
    4,982
    The iPad adds info into the photo that turns photos right side up, even if you took them holding the iPad upside down. Not all photo readers on other platforms understand this. The easiest thing to do is to make sure you hole the iPad (or iPhone) correctly; (with the camera on the top edge) when taking the photos.
dropbox favourite folder ipad
dropbox mark folder as favorite
how to select files for syncing in dropbox using ipad
how to sync dropbox folder to ipad
how to sync folder to ipad
ipad sync dropbox folder
sync dropbox folder with ipad
sync dropbox folders on ipad
sync ipad with folders to computer
syncing pc files to ipag
